brian015
brian015's Avatar
02.09.2011, 09:55 AM
I fear Linc's suggestion of inverting it may end badly. It was designed knowing heat rises and the components are stacked in a way that the heatsink is on top to pull heat up as well as the fan pulling air up and out. You'd have to keep it awfully cool to compensate for that.
I don't think this is much of an issue. Hot air rises (because it is less dense). That doesn't mean that heat rises in general. A heat sink physically connected to heat-generating electrical parts will absorb heat no matter which side it's connected to.
Another consideration - with DrKnow's overpowered set-ups, his trucks may spend as much time on their lids as upright - negating the effect of how the esc is oriented.
