02.09.2011, 11:29 AM
The only downside to mounting the heatsink to the chassis I can think of is stress on the components. Con't forget the heatsink is thermal-epoxied to the FET casings - and that's it - so all the stress from jumping, rough terrain, and bad landings will be transferred directly to the FETs, which are relatively fragile. Unless you plan to do something different, the FETs will also be supporting the weight of the entire ESC and all the G forces will be acting on the FETs.
This is true. The esc really needs to be mounted in some manner, then the heatsink can just be used to remove heat.
I do worry about the shock, not sure how that will affect stuff.
I do know that if you do not mount an esc sollidly you will have issues with it. That is whay I use double sided tape and zipties whenever possible.
