03.04.2011, 02:09 AM
I did this mod to my dx 6 about a year ago - You just have to be vary carful when removing the prongs from the old unit - Well easy to rip the pad off of the board in error.
Good info Chris. I will be extra careful. Have you been happy with the mod? What battery do you use in your dx6??
Also, since I am sure you have run a car esc with your dx6, is there anything I should know before I try to get a MM working with it? DO I have to set the trims/expo/etc weird on the channel I plan to use a throttle?
