Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
ta_man
03.05.2011, 08:16 AM
I've been thinking the same thing. IIRC, it uses 14mm hexes, so that's one thing that'll have to be changed (to use 12mm hexes). Aside from that, the only possible roadblock I can think of is to make sure the axle carrier unit will fit inside the wheel hub.
That is why I asked - I was hoping someone could take the 14MM hex off and just see if a 2.2 wheel would fit. I can get 12MM Tekno hexes for 6MM axles but was hoping not to have to spend $400+ on the truck just to find out if the wheels will fit.
Originally Posted by reno911 View Post
2.2 for a 1/10 truggy, there are only two out there the ofna and the tent I am not sure to the hyper tt wheel size, but that seems small for this class.
Exactly: the class is designed primarily for the Ofna and Hyper and any other 1/10th 4WD the same size as a regular 1/10th 2WD stadium truck.
