Go Back   RC-Monster Forums > Questions and Answers > Frequently Asked Questions (FAQ)
Scoob
Scoob's Avatar
03.15.2006, 08:20 AM
I used to be the worst at soldering and I hated it but I finally got it and am pretty decent now. I don't know how much it will help you but the single biggest help for me was using a wet sponge to clean the tip. My tips always got to the point where they would not heat the solder and when it did the solder would just fall off the tip. Cleaning the tip took care of both of these problems. Every couple minutes clean the tip and you can get alot of the black off. It seems like my tips always have to "break in" before they'll transfer heat worth a darn. I don't use the pointy part of the tip, back away from it a little and look for the shiny part to tranfer heat best.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
03.15.2006, 08:39 AM
I noticed with my screw-on tips, they didn't transfer heat that well. Then I saw somewhere that you need to use pliers to really screw them on there. After trying this, it seemed to help a lot with heating. Scoob, if you have screw-on tips, you might want to try using some pliers and tighten it down for better contact and heat transfer. Make sure you don't over-do-it, else you might strip the threads. Just tight enough so you can't easily unscrew it with your fingers.
macfjej, like I said before, I have that exact soldering iron. It has worked fine for me and will probably work fine for you. I do, however, suggest at least a 60w iron for soldering batterys together so it will melt the solder faster and not heat up the battery. I just had to take my batteries to my LHS to get them soldered, but I may just get a stronger iron next time because one of the cells blew up after a few runs:035: and I don't want to blame them, but I think it was due to incorrect soldering. I think you can get a pretty cheap 60w iron from Tower Hobbies for about $6. Clicky!
Good Luck,
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
03.15.2006, 09:56 AM
That is good advice. I would like to add that you should periodically check this, especially when the iron is hot (use pliers!). The cooling and heating cycles tends to loosen the threads after a while.
