Go Back   RC-Monster Forums > Questions and Answers > Frequently Asked Questions (FAQ)
03.15.2006, 09:56 AM
Originally Posted by brijar
I noticed with my screw-on tips, they didn't transfer heat that well. Then I saw somewhere that you need to use pliers to really screw them on there. After trying this, it seemed to help a lot with heating. Scoob, if you have screw-on tips, you might want to try using some pliers and tighten it down for better contact and heat transfer. Make sure you don't over-do-it, else you might strip the threads. Just tight enough so you can't easily unscrew it with your fingers.
That is good advice. I would like to add that you should periodically check this, especially when the iron is hot (use pliers!). The cooling and heating cycles tends to loosen the threads after a while.
