03.12.2011, 01:44 AM
Startup loads would be massive. Plus unsprung weight would be very high so handling would be crap. Replacing the diff would be better, but you still have the high startup load to consider. I personally like the direct to diff, ie replacing the center gearing/trans with an outrunner.
I have plans to do a dual outrunner direct to diff setup on a 1/5 scale car. I will have to use 2 esc, but I can basically mount the outrunner shaft directly to the pinion gear. So it will open up the center of the chassis to allow all of the componets (batteries, escs, etc) to be mounted right on the center line.
Cody.McP
03.12.2011, 01:54 PM
Ditto on what the pimp said. I was thinking about doing something like this in a Baja but there would just be a ton of unsprung weight and it is too complicated/expensive to be worth it IMO. 4x MMM, 4x 6s Lipo, 4x Motor = $$$$. If I was to build a crawler (without any real knowledge of crawlers) I'd maybe give it a shot and have some system set up where I can power any of the wheels individually on demand, would make kind of a cool traction system.
