Ko Propo charger.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Ko Propo charger. - 03.18.2011, 06:05 AM
Also how about this charger?
http://www.amainhobbies.com/product_...rger-6S-5A-50W
The specs look pretty decent for (1S-6S) for the average R/C guy. I doubt that I am going to be using much above that for a while anyway. Just looking for some opinions in input on what is available in comparison. Of course none of us wants to spend more than we have to, but I also want to be safe and get a good product that will last for a while. SO what do you guys think?
SUPERMAXX YOUR LIFE.
whitrzac
Can't catch this...
whitrzac's Avatar
03.18.2011, 06:29 AM
link fail...
I trust my "homemade junk" over most of the power supplies at amain. I saw one of the older protec(?) ones with the red front panel overheat and nearly catch fire...
my "homemade junk" are used in servers that have $10000000000000000000000000 of dollars worth of info on them...
If you would like, I have a few power supplies similar to the HP one listed, except they are 50+ amps at 120v and 100+ at 240, all in a box that is smaller than most of the 20 amp ones at amain...I usually do 4 outputs, and all of the contacts are covered with black silicone. I charge $40 local for them, and shipping would be $15ish....
I use this charger...
http://www.amainhobbies.com/product_...er-6S-10A-250W
Photos??
JERRY2KONE
JERRY2KONE's Avatar
Photos?? - 03.18.2011, 07:04 AM
LINK FIXED. Thanks.
I am curious of course to see if yours are any different then what I have already seen available. Do you have any photos of your setups? If it were just one power supply without any home made wires used to make it fit the privately intended operation, than maybe it would be considered legally acceptable for charging batteries.
Like I was explaining home owners insurance companies look for excuses like that to exclude payments for damage when a home made device is indicated as having caused the fire in a home. They call it "owner neglegent causes", or something like that. I am not willing to take that chance, because we live in privately owned homes that are contracted by the US Gov for our use in various countries around the world. Nor would I take that chance in my own home. I have seen some of these dual power supply systems joined together to acquire the needed voltage and amps supplied, and they are still not setup up safely for home use. You may have one that will work fine for 100 years, but all it takes is just one to malfunction and someone is going to end up in the poor house with absolutely no recourse for recovery. That is not going to be me.
I want a lagitimate power supply that is patented and designed for the intended use of supplying power to an R/C battery charger. Yes of course I would like it for a reasonable price with similar benefits to this Protek model, which is why I posted the question here. Home made electronics cause way too many house fires for me to risk my home or my family to save a few $$$. I also plan to use a gutted BBQ grill for a charging station rather than just having it setup on a workbench, which will give me at least some protection if a Lipo decides to let go while charging. Sure Lipo fires are somewhat rare, but they do happen. SAFETY FIRST.
