bumsnogger
03.31.2011, 01:19 PM
Hi.I shredded the esc to rx wires(they got under the spur guard during a field repair) .I resoldered 'em,now I've got reverse.Typical,I just bought a field card so I could get reverse without using the wrong castle programme and frying the esc.Oh well,I've got reverse :)
bumsnogger
04.05.2011, 03:29 PM
Hi.I've fitted a wheelie bar & alloy slipper clutch :) Wheelying accross the carpark.Gotta take it out for a beating tommorrow :)
bumsnogger
04.18.2011, 02:58 PM
Hi.Broke the wheelie bar :( .I keep knackering driveshafts.But, I took the pin out of the shaft,put the bit that goes in the wheel into a drill,pushed it into the shaft a little deeper,dremelled the plastic off where the pin was.I moved the pin hole inwards 1/8th og an inch.Hopefully it'll work :)
bumsnogger
04.24.2011, 09:57 AM
It works a treat :)
04.24.2011, 11:10 AM
Pictures?
bumsnogger
07.27.2011, 10:53 AM
Hi.the previous mod kind of worked.BUT,I've come up with another that stops the crosspins moving & splitting the plastic bit.I got some appropriate sized rod/pin,Drilled 1/16th of an inch into each end,put it in place ,then peened the ends out :) I beat the crap out of the truck a couple of days back with NO driveshaft failures
