zueslilbuddy
zueslilbuddy's Avatar
04.01.2011, 04:17 PM
Originally Posted by Candyman2 View Post
If your putting a centre prop shaft in make sure you use something like 8mm/10mm tube to extend it. Dont be tempted to use bar as it will bend, has to be tube.
Thanks for the advice but I'll be using Hardened Steel rod.
Having it made up at the machine shop very soon.
It will not be welded, but will be like v8hatch's with the set screws to make it easier to change out the shaft ends if I happen to break a dogbone end or cdv end.
