Aussie Nerd
04.01.2011, 09:53 PM
Looks like a typo on the 9380 as is should be .13 sec. The specs are essentially the same as the 7940/45/50 but sip power and do not slow down as they are heavily loaded. Playing with the sample I got last week, I would hang 10lbs of weight on the highest speed version and it drew only .23A... the similar 7940 was 2.5A. Even when stalling the servos (can handle this indefinitely BTW!) it was only 1A. The servos are also dead silent and the programmability goes way beyond what we have now. You can modify torque zones so that on a throttle for example, you can set the end's so they draw almost no current when reaching a hard stop. Of course there are basic and advanced programmable options and if you get too far out of whack you can just reset to default or a previous configuration from a saved file. Also, each servo can be named and the history of it's usage is logged. So if someone sends a servo in and says it's new, we'll know if it really is!
FYI: These are nothing like the current competitors brushless servos, the motor and circuit have been several years in the making. The performance of the servo does not change above 7.5v so it will stay the same through the discharge of the battery. It also has a regenerative circuit which actually charges the battery when decelerating much like the high end ESC's for R/C cars therefor you'll be able to use much smaller batteries and still have plenty of run time. This is a huge advancement in servo technology as never before have we had so much power with so little current draw; it's like your corvette now gets 50MPG!!!
$179.99/July
Mike.
This is a post from the link j.f.s posted. Looks like the dreams for a fast and powerful servo have been shattered. Also I hope the thing about performance not changing above 7.5v sentence, doesn't mean that torque is the same even when the servo is overvolted. Looks like i'll be sticking with futaba after all.
Kieren
