Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
thzero
04.18.2011, 06:08 PM
It's a Monster Truck, of course it is. ;) But yeah, I like my RC8T... although am running it now with Baja 5B tires!! But they are definetly different animals.
I don't have the standard Flux TVPs only the nitro TVPs, but I do have the TCS Flux TVPs. Unfortunately I don't have exact weights, but I would say they are about double (2.5mm vs 5mm) the weight; but what you make up in weight you get back in more strength. Again, its a Monster Truck not a truggy!
Nonetheless, I like your build. Is the Revo tranny really that much better than the HPI? From what I've seen and remember from running a T-Maxx 3.3 its really not. But I'm curious. One of the PITA parts of the Savage Flux is changing pinions (you have to pull the entire side of... wtf?!) [no Jahay, I'm not going to use a center diff!] and by using the Revo tranny looks like its much easier to get to.
I've switched to using FLM's draglink and body braces on all my Savages. The later definetly help reduce flex and the former works better when using high-torque servos.
You should probably want to ditch the battery door tabs and use velcro straps instead; maybe even flip the battery boxes around so the doors open up. I've found for me that by cutting off the battery door tabs, getting rid of the 'hump' at the rear of the battery door, I was able to use all my batteries without going to reversing my battery boxes (which caused issues with bodies too boot).
I'm also running GCMs (get them through tcscrawlers) battery box attachments. Much more solid than the plastic versions.
Originally Posted by Ola View Post
I just felt the Flux was VERY top heavy.. It wheelied for nothing, tipped over to easy, and rolled forever if it got started lol
I`ll post some RC8T pics right away, as i am alittle proud of it LOL! If it runs as good as it looks, it will be ALOT of fun :) Check for new thread here on RCM..
