brian015
brian015's Avatar
04.20.2011, 02:26 PM
Originally Posted by TroubleMan View Post
ok i ran it 14/48 and i was pleased around 57mph's but !!!! i can't put it on the motor would touch the drive shaft !!!!!!!!!! lose the wheels or find a bigger spur
That's why I have an RC8T CD (54t spur) for my latest build with the 1717 if I need it - the diff itself is the same width as the Muggy/8ight diff, so it will fit in the Muggy mount.
I'm looking at using the 8ight-T 50t spur right now if I use smaller tires:
http://www.rc-monster.com/forum/showthread.php?t=29657
Your other option would be to run Muggy diff gears front and rear (45/11) which would also help your gear ratio - the problem is that those ring/pinion gears are getting harder to find.
Can you file down the fins on the motor to make it fit? That might be your easiest fix.
