Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
04.20.2011, 11:44 PM
The 180 cells that make up the 6S pack, took back 45,000mah to become fully charged again.
Whew! I need a bigger charger. LOL
This means all day fishing used 63% of the pack's total capacity.
Now we have enough data to figure efficiency losses.
The watt meter measured 65,500mah worth of useable energy going to the motor.
On the high voltage side, this translates into 32,750mah of energy
Hmmmm..........73% total efficiency. That's not very good really.
I think a large amount of the losses came from the wire that I'm feeding with. 10Ga. Silicone does get warm when feeding 50 amps continously for extended periods of time. The wire was probably 95 degrees on a 70 degree, fairly windy day.
Traxxas High Current connectors are used to attach the silicone leads to the trolling motor lead. I noticed the trolling motor lead was a little warmer than the silicone portion of the lead Entire lead length is about 7 feet.
Hmmm........perhaps replace the entire harness with 8Ga. Silicone.
I could detect very little heat coming from the converters.
This pack does still serve a good purpose and I'm looking forward to the fact, this setup could live and give for 10 years.
