Bmr4life
04.29.2011, 08:43 AM
Originally Posted by steveo View Post
are you trying to cut your grass at 15 mph or do just want to be able to drive it that fast, 2-4 mph is what you need to cut with any faster wont look so good, the mower will hop
2-4mph, thanks. I don't plan on cutting at high speed, but I do want it to have a high speed option for getting from A to B between cutting.
Also, I picked up a used/broken Razor for $15 off CL. Hooked the battery directly to the motor and it works just fine. Probably something wrong with control module which I won't be using.
steveo
04.29.2011, 10:20 AM
after i saw this thread i went to youtube you should do the same
Bmr4life
04.29.2011, 10:21 AM
I've seen the vids on youtube. Have you seen something in particular?
