Liquid cooling vest help
whitrzac
Can't catch this...
05.02.2011, 11:51 AM
look into water cooling setups for PC... Most of the modern ones use larger hose, but it should be fairly easy to adapt them, and they run on 12v.
a pump+small reservoir+a radiator would set you back $100ish
examples, stuff can usually be found for less
http://www.frozencpu.com/cat/l1/g30/...ml?id=xrRkp7Eq
whitrzac
Find all posts by whitrzac
