Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.07.2011, 04:26 PM
Geared to high and the Lipo needs/should be 40C+ for best performance and to be able to supply the amps needed.
Thicker CD fluid100k will help to prevent tire balloning
Your prob geared realistically for 55mph+
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 18
Total Voltage: 18.50
Motor KV: 1800
Tire Diameter (inches): 5.5
Tire Ballooning (inches): .25
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.44 : 1
Total Ratio: 10.51111 : 1
Tire Circumference (inches): 18.85 inches (478.78 mm)
Rollout: 1.79:1
Total Motor Speed: 33300 RPM
Vehicle Speed: 56.55 mph (90.84 km/h)
Effective KV Value: 1800
KT constant: 0.75 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
