03.16.2006, 08:36 PM
just to let you know what I got in my g2r is a feigao 10L and hacker comp with hitec 5645 servo locked trans in second gear, you can substitute 10L waderer and 9920 for the combo I got since the hacker comp is unavvailable
Site Owner
03.19.2006, 01:26 PM
You should see a reply to your email later today, tally. :)
Site Owner
And welcome to these forums.
03.19.2006, 04:29 PM
thanks mike. this forum is great!!!!
03.21.2006, 09:09 PM
o.k last chance to change my order. from what everyone has told me i will order a lehner 1950/8 and a bk 12020 from mike. sold??????? also i will run 6 cell lipo.
03.21.2006, 09:12 PM
sounds good. i think the 9920 would be ok although im not sure.
03.21.2006, 09:13 PM
when it rips out your drive train you can sell it to me 1/2 price LOL
03.21.2006, 09:17 PM
is it really going to kill my drivetrain?
03.21.2006, 09:25 PM
Dont worry, it should last for a while if you dont go too hard on it.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
03.21.2006, 09:32 PM
easy isn't an option. i'll be racing lightnings and hellfires, so i need to know for sure. if i use cvd's, al. diff cups, al. diff housings, gmaxx tranny with steel idler, what else will strengthen drivetrain?
03.21.2006, 10:22 PM
That should be strong enough to withstand what your running. It should withstand a even a bit more than what your runnning with all that! And IMO, you can stick with the stock drive shafts . they should hold up fine to the power. They are quite beefy.
Losi 8ight e
03.21.2006, 10:33 PM
thanks sylvester, this is my first "custom maxx type" vehicle so i'm relying on other peoples knowledge to guide me. i completely trust this forum!
03.21.2006, 11:09 PM
done! finally ordered 1950/8 motor, 12020 esc, and 6v ubec. thanks for all the help, i'm sure i'll have a few more questions for the "brushless experts" on this forum. can't wait to get the chassis and all the other things required for this build. should be a week or two!!!!!!:004:
03.22.2006, 07:24 AM
I would make sure you havea good slipper and not have it overly tight.The diffs are your weak link in the truck. YOu running lipo so that will cut back on weight and help with driveline problems. I run the 1950 8t hi amp version. It is more than the xl cans i ran. A strobe slipper is great if you don't have one. Since you will be racing I would assume you running not a big tire. I recommend starting with 15 51 geearing for it.
03.22.2006, 08:07 AM
thanks for the gearing info coolhand. yes i will be ordering a strobe slipper with my next order, and will need help adjusting it properly. as far as diffs go, i will get al. cups and cases. is there anything else i can upgrade in the diffs?
