Dafni
Dafni's Avatar
03.20.2006, 04:23 PM
Yes, that's me on the pic, indeed. Standing on renes staircase.
The vid is also in Holland. Now I'm back home in Switzerland.
The driver in the vid is my friend Marc, who's an experienced nitro buggy driver.
Romster, I never had it on a track against nitros, but Marc says it is as fast as his OS.21 buggy (and I had the throttle on 80%).
Yes, Serum, I bent a shock shaft. I think it happened when I wedged it under this beam on the far end of the spot in the video.
A bend shock shaft is not bad, considering the beating it took.
coolhandcountry
coolhandcountry's Avatar
03.20.2006, 07:00 PM
Maybe you should let your friend marc race it one time to see how it compares out. You may be able to convince him to go brushless on his buggy. You could sell him a mount for it. ;)
boss 302
03.20.2006, 07:01 PM
yeah if it is as fast as his buggy there shouldnt be any problems with him racing yours.
Romster
03.20.2006, 09:52 PM
So here on this forum who owns a Lehner 1950?
-What Turn is your 1950 motor?
-What Esc are you using?
-Do I have to worry about heat issues, Esc and motor...
Dafni
Dafni's Avatar
03.21.2006, 02:58 AM
You can bet on this! Unfortunately he lives in Sweden now :( We "met in the middle", at Serums place.
Last summer I was in Sweden for two weeks, and Marc and me spent every free minute on tracks. I brought the Revoxx, and we were exchanging transmitters all day long. Marc is like the brother I never had to me.
Yes, Boss, he can drive. I let him drive my stuff without the least worry.
Romster, e-mail sent :)
coolhandcountry
03.21.2006, 07:53 AM
I have a 1950 8t hi amp. I run it on a 9920 with no heat problems. I run from 14 to 20 cells as well. Depends on the tires i have. I run from a 14 - 20 tooth pinion with 51 tooth spur.
Romster
03.21.2006, 10:18 PM
So if I use the BK 12020 Esc and a 1950 6 turn gear at 18t or 20t pinion on 14 to 16 cells. Should I be fine?
Dafni
Dafni's Avatar
03.22.2006, 02:27 AM
You have a 44t or 47t spur, right? I would start with a 14t pinion.
Romster
03.22.2006, 10:52 PM
I am using at the moment a 46T spur center gear. I could also gear up to a 53T spur gear.
Romster
03.22.2006, 11:02 PM
Coolhandcountry What are you using for a motor mount for Lehner 1950?
I have one of GriffinRu motor mounts and I am not sure if it will fit. Need to find a motor mount before I purchase 1950 motor.
Gustav
Gustav's Avatar
03.22.2006, 11:28 PM
The 1950 fits a standard 540 motor mount,so if it works with your 9L it should fit.
Romster
03.23.2006, 12:09 AM
I heard on the Lehner 1950 the Bearing my be too big to fit thru the motor mount. I am sure the mounting screww holes will fit correctly. But not too sure about the bearing part of motor.
Romster
03.23.2006, 12:13 AM
I mean, 1950 bearing may be too big to fit thru motor mount. But I am not sure. I have not really seen the shaft side of a Lehner 1950.
Gustav
Gustav's Avatar
03.23.2006, 12:45 AM
Err,drill?:005:
Sorry,the bearing's only about 10mm,can't remember exactly,and extends about 1mm,just run a drill through it if it's too small.
Romster
Smile 03.25.2006, 09:13 AM
I like to thank everyone on this thread for helping me decide. I really appreciate it guys........
I am going to get the 1950 6turn...OOOYeah!!! can't wait....
thanks again Guys...:018: :027:
