swiftneed
swiftneed's Avatar
07.24.2011, 05:38 PM
did you check your remote to make sure the steering is in full position meaning the settings for the steering servo the next thing you want to check is the your tires the allen set screws for the camber may be too tight loosen them up a bit and try the steering, take off the wheel there should be Two set screws good luck
  • RCM XT8 MMM NEU1521 1Y AKA TIRES HITEC 7955 TG 6S
  • MBX6T MMM CC 1518 HITEC 7955 BRAKE 5645 MG 6S LIPO
