New Motor Mount Idea...
New Motor Mount Idea... - 07.25.2011, 11:25 AM
A generic Nitro to Electic mount - uses nitro hole spacing to the secure mount.
2 piece design like the revo mount with mutiple front to back positioning holes for both long shank and regular pinions / electri-clutch...
This should also work as flux mount if I'm thinking correctly
whitrzac
Can't catch this...
whitrzac's Avatar
07.25.2011, 11:27 AM
*cough* tekno *cough*
TexasSP
Something, anything, nothing
TexasSP's Avatar
07.25.2011, 01:02 PM
The Tekno is too limited. I think Arct1k is after something much more versatile.
www.cubicle101.com
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
07.25.2011, 05:39 PM
How so? Isnt that exactly what the Tekno was designed as?
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
pinkpanda3310
pinkpanda3310's Avatar
07.25.2011, 07:28 PM
Make the lower part of the mount offset front to back and reversable?? One end for long shank the other for short.
whitrzac
Can't catch this...
whitrzac's Avatar
07.25.2011, 08:11 PM
were would you mount the batt?
07.25.2011, 08:59 PM
Depends on the vehicle- look at any revo, truggy, buggy, truck or onroad conversion & there is always a suitable spot for atleast one lipo pack, even if it needs a tray or straps attaching to the chassis.
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.25.2011, 11:09 PM
The problem arises with the nitro mount holes that are drilled in the chassis. Different models have different spacing (length wise and in width) and/or the location relative to the spur gear. Something designed to work in an old school Ofna wouldn't work in an 8ight, an 8ight wouldn't work in a MBX6, and none of those would work in a Savage.
Although my mind is conjuring up something with quite a bit of adjustability that might just work in most if not all. Too hard to explain, gonna have to get it on paper. I think it might end up a tad expensive to machine though
whitrzac
Can't catch this...
whitrzac's Avatar
07.25.2011, 11:34 PM
your over-thinking this... most .21\.28\etc motors use the same height/size/etc of mounting hoels. Get a motor to attach to those and your golden.
pinkpanda3310
07.25.2011, 11:50 PM
How about modding the flux motor clamps to make it work? ie; make up a bottom plate for it with countersunk screws going into the motor mount. Drill and tap some holes in the bottom plate to match the existing nitro holes.
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.26.2011, 12:00 AM
Making an e-mount that bolted onto the nitro engine mounts would make things alot less complicated. But it would also raise the motor up quite a bit more than other more traditional e-conversion mounts. I'm pretty sure a 15xx motor is bigger in diameter than a big block nitro motor and would never sit between the mounts like the nitro. Not that this is a concern for everyone, especially budget minded folk.
That's the Fine Design solution to motor mounting. Problem is you need different diameter clamps for different diameter motors. Not always a problem, but it can be, especially if you're looking for a bolt on (no dremel) solution to every application. Which seems to be what the OP was suggesting.
07.26.2011, 12:44 AM
any of Mike's mounts have the spur and motor mounted on the same single piece for a reason. (except revo) Chassis' flex. A motor mount separate from the spur bulkhead is simply an inferior design.
scarletboa
scarletboa's Avatar
07.26.2011, 01:20 AM
my CEN buggy goes through spur gears a lot faster than my ofna lx1-e. the pinion gears are the same, the spur gears are both plastic, and the motor is the exact same. the only time my ofna chews up a gear is when the motor mount screws come loose. my CEN buggy will chew up a gear occasionally, especially if i am doing some big jumps.
the ofna has a center diff mounted motor mount
the CEN has a chassis mounted 4-5mm (very thick) aluminum angle motor mount.
in my opinion, mike's newer style motor mounts and the elite-rc motor mounts are by far the most durable, effective and precise motor mounts that money can buy. i like the price and looks of mike's mounts better, but i like how the elite-rc mounts are very easy to adjust gear mesh with. to be honest, if mike's mounts and the elite-rc mounts were the same price, i would choose the elite mounts first. that easy gear mesh adjustment is what i really like about them and what i would love to see in mike's motor mounts.
pinkpanda3310
07.26.2011, 09:21 AM
Is it just me or are those elite-rc mounts a losi ripoff?
There's some contraptions getting around now but the more moving parts the weaker it will be generally. The integy mount is laughable
ID:	10091   Click image for larger version
Name:	hpi forza mount.jpg
ID:	10092   Click image for larger version
Name:	integy mount.jpg
