Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
cmac
cmac's Avatar
09.03.2011, 02:21 PM
Given it was designed for racers with lighter vehicles, your setup may just be a bit too much for the slipper, in which case add an extra wave spring. You shouldn't run out of thread then.
So I would like to know if you tried the third wave spring and if so did it work?,or did you get it worked out some other way?
pinkpanda3310
pinkpanda3310's Avatar
09.03.2011, 10:59 PM
To be honest I haven't tried it myself, haven't felt I need to. Though I do have a spare set of springs so I can try it, just won't be able to drive it until parts get delivered
jamesban
09.04.2011, 02:32 PM
I got the third spring on last night and with the third spring and it tightened all the way down it works! The front end comes off the ground a little tiny bit on launch but no more flips or wheelies and my drive train should be safe now. So I guess with 3 springs it will work good on a huge truck like the muggy. Im happy with it now. Im running a 15t pinion, 4 cell A123 batteries and a 40 x 82 mm 2000kv 4 pole leopard motor. It moves pretty good! I will try to get some video posted when it stops raining.
cmac
cmac's Avatar
09.04.2011, 02:53 PM
What diff fluid are you using in the slipper?, and do you know how much you truck weigh's?
jamesban
09.04.2011, 03:49 PM
I was using 50k but last time I rebuilt it I had no fluid left so i just used diff grease. I have no idea how much my muggy weighs. Im guessing around 13lbs.
