Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
jamesban
09.05.2011, 11:01 AM
Originally Posted by _dV View Post
Pity I didn't spot this thread sooner as I had the same issue with the slipperential in a Savage and solved it the same way
http://www.rc-monster.com/forum/showthread.php?t=27208
One thing note is to make sure the overlap points in the 3 wave springs are evenly spaced out when you put them on. This seemed to be part of the issue with just two as when they were really tightened down it seemed to create uneven pressure on the slipper.
I could actually use 4 springs on mine if i wanted more adjustment area cause I got the springs flattened now. But im good with it where it is
