NickRummy
NickRummy's Avatar
09.09.2011, 11:52 AM
Originally Posted by BIG-block View Post
Part of the reason that I haven't sent my one in. I figured they would be swamped with repairs at first and the fact I am using it on a 1717 in only a XL Savage should make life pretty easy for the controller. I am just going to use it and see what happens. Maybe after the summer is over I will send it in. Given the fact that spring is only starting here that will be some time away.
I'm kicking myself for not taking your approach and actually thinking about buying one I found to use until the repairs are being done.
Are you running your 1717 on 6S or 8S?
BIG-block
09.09.2011, 12:00 PM
For the start I will run a few packs through it on 6S and just make sure everything is fine and then up the ante on 8S. I have quite a few 4S packs here waiting to be used. LOL. Anyway I am not even the slightest worried about the ESC. What ever happens to it happens. I am using it within it's specified parameters and anything that might happen to it should be covered by the warranty. I am more worried about the motor. 1717 don't grow on trees. If I blow it on 8S I think I will just cry but I am hoping that Castle was being a little bit conservative on the RPM limit. If the worst happens and I do toast the 1717 I still have a 1520 sitting on the shelf.
