RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.19.2011, 12:56 PM
I should be able to get an LST/aftershock version done in a few days easily enough - right after I finish making a conversion for the Agama 8 buggy. I can make a shim and include it with the mounts for 1717 fitment easy enough I guess - I don't have a 1717 to test, though(I may make up a dummy to work with after looking up the specs).
The Savage is very restrictive by design, so motor placement(height, fwd/bkwd placement, etc.) is critical. The mount now is a compromise to allow the most options with the least fiddling, but a minor trim of the tranny case is required(must trim about a 1-2mm off the plastic leg that screws to the motor plate). The MGT and LST don't have this limitation, though.
