Originally Posted by a6m532
Hi,
Does any one has problem installing a smaller pinion like 22t with a 1520 motor The 5mm chassis is blocking the tools so you cant tighten the 2 outer screw. I have correspond with alza racing, and he has come out with a solution. Still waiting for the modified motor plate and mount to reach me.
all 5mm chassie and stock motor mounting have the same issue, i have 4mm and the 1717 mount and have good clearance.
Have experience the same issue as you mention with tcs plates and stock motor mount
