rawfuls
roofles.
rawfuls's Avatar
01.06.2012, 02:00 AM
Very good points Jerry..
Though I'm just not totally set on the difference between SLA and Lipos.
In my experience, SLA seem to decrease and sag immensely over a short amount of time under load, especially during spikes.
However, lipos can USUALLY keep their capacity and keep on trucking.
In addition, I feel that the the stock solid wheels weigh a ton, and switching to some 10" pneumatic tires from harbor-freight, and after managing to fix it to the axle, that it should run much smoother.
Though, I'm not too sure, since I have not dabbled into the complexity of much electrics as others (linc, or briang) have.. Maybe their input would tip the scale.
I'm pretty much leaning towards dropping ~$25 bucks on some new wheels (if they don't work, I could always return them, or give them to my dad to create something with). If somewhat of a speed/torque increase is shown from actual grip coming from the tires, then I will probably pick up one 6S 5000mAh 20C battery, to give it a try. If it exhibits something that I'd want, I'll pick up another of the same battery, hook them in up in parallel, and have it as a 6s 10Ah pack.
In other words, I have dropped the idea of going brushless, and will be seeing what I can do with the stock setup.
