b0gh0s
03.29.2006, 08:29 AM
Hey just an FYI, you don't need the one way back on there as a spacer, I have been running mine for a while now without and it works fine.
This mod works exactly the same as the hub I milled to replace all of this, basically you are locking up the second gear to the shaft instead of the clutch doing it. If you reassemble correctly the gear will be held into place on the shaft and won't slide, the shaft is turned down at the end and won't slide further into the bearing than it is supposed to. You can lock the tranny in either forward or reverse and it will work, I have my locked in reverse and the motor is just setup to go the other way.
Good work around dude!
