extremexmods
03.29.2006, 12:19 PM
Thanks guys.
What about dual lehner Basic XL 2400 motors, geared 23 pinion, 64 spur, with 20 cells? And do the cells really put out a full 1.2 volts? I thought they put out a little less, making 20 cells on a Lehner Basic XL 2800 possible. If each cell only puts out a max of 1.16 volts under load, the rpm would be only 64960 rpm. I am running new GP 3300 cells, in a side by side racing configuration, not stick packs. I want the lehner because I insist on a screwed, not a pressed on motor endbell, and my friends all say Lehner makes the best motors for the price, $150 per motor is the most I want to spend, and I insist on the awesome look of dual brushless, I refuse to run single brushless. I just want to know if my set up is safe. I though if the batteries never put out more than 1.16 volts, the rpm would be safe. I should have said 20 cells, not 24 volts, because I know the cells would put out less than 1.2 volts each. And I would not run the motors without a load. What other websites sell brushless motors?
