ambryatim
01.23.2012, 11:29 AM
Ok, Thanks.
Now say it is the batteries....then why would it drop out for a minute then go all out like it is supposed too??
From a dead stop it will take off like a raped ape (most of the times) it is more when I lightly apply the throttle or I am already going and pin the throttle that this will happen.
Batteries are new (still could be bad though) they are a 40c 5400mAh nano-tech.
Edit: you are correct in the problem being the batteries....I turned off the lipo cut-off and it does not hesitate any. So, I will try to dial down the punch to see if it helps.
Are Gens Ace good batteries?
Thanks.
