Overdriven
Destroyer of Tires
Overdriven's Avatar
01.31.2012, 10:41 PM
I would think the front and rear body mounts wouldn't be too hard, just raise them up or reverse them if need be to line up better on the body. As for the sides, I think you might be overthinking it a bit. You'd be suprised what you can do with some flat plate and "L" aluminum pieces, a hacksaw, and some files or a dremel with a sanding disk to clean up the edges. With that you could make up some mounts for extended Traxxas body posts to use for the sides. Might not be quite as polished as a cnc'd part, but you could remake them a couple times until your happy for alot cheaper with stuff you bought at home depot.
