Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
rcs2022
02.01.2012, 02:18 PM
I am a bit ahead in status, but want to go through the steps.
Here is a blowup of the parts for the center diff and motor support:
I'll be using 3mm Alum plates attached to the TVP's; 6mm top and bottom alum plates for supporting the center diff; and 6mm motor mounting plate. the motor will be supported on the back plate using 4 screws; 3 screws going through the 3mm plates will be used for mesh adjustment.
Mechanical brakes will come later, but here is the general idea. Will have to mount the springs on the other side; and probably gotta notch the back 6mm motor plate. Haven't tried mech brakes on a brushless setup before, i dunno if while ESC is in forward does the servo rotate as if applying throttle in a nitro?
rcs2022
02.01.2012, 02:22 PM
Well on with the build.
Here are the first cut plates:
First test assembly, to check alignment.
I offset the Motor and Diff as much as possible to lower the motor as much as i can, to achieve a lower CG.
rcs2022
02.01.2012, 02:32 PM
Now with the first test fit, I used the XL rear dogbone in the front and found a 109mm dog bone at my LHS fit perfectly, even with the offset motor and diff. Servo already relocated as shown.
rcs2022
02.01.2012, 02:44 PM
I supported the whole mount with motor and diff using 6 screws going through some holes in the TVP's and even used the rollbar screw as a support also, I tapped the 3mm plates for easy installation and dismantling. I like how low the motor is. The mesh adjustment moves the motor up and down, so as i gear up the motor has to be raised, buts its minimal. now installed with a 15mm pinion and 50 spur.
View of the rear, hoped by lipos would fit there. actually they don't.
View of the Front. The Motor actually clears the TVP's by a mm.
And please excuse the cleaning of the truck and the crude cuts in alum Was anxious getting everything together and testing. Will grind and file the pieces later on.
Also to mention the servo arm clears the motor; here the servo is at full swing. hoped i could swap the dogbones to move the motor more forward but they would get in the way of the servo arm.
