03.05.2012, 08:38 PM
If all you have is a 2650 on 6S you really need to be careful with gearing...my suggestion is get the correct motor for your application and it will help tremendously. On 6S a 1400kv Tekin motor would be perfect and probably run cooler and more efficient with proper gearing
Having the correct motor/batt/esc combo is a huge reason why people either have success or have problems. It took me awhile to figure all that out and it ended up costing me a couple of motors and esc because I did not take the advice of many guys here. Better to buy the correct motor for the amount of cells you are using....makes a huge difference
