aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.06.2012, 10:07 PM
Originally Posted by killajb View Post
A simple center diff (or spool) and motor mount is the way to go. No offense to your fine work Aqwut, but the extra gears used to install a gasser just don't seem necessary for electric use.
Non taken, I like to keep things stock as possible for ease of parts replacement. Plus, using a big motor you would need support for back end bell as well. If I had the machining skills, I would have done it different.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
