Bad battery!
anunaki
Bad battery! - 03.20.2012, 07:36 PM
Hey buds just recieved my rx battery and it has no charge at all what do I do can anyone helpme revamp this its a 1300mah lipo rx nanotech battery it'll cost memore to send it back
Somone I.know said somthimg about charge it on ni cad but I dont know about that somone please elaborate and help me out thanks guys.
brian015
brian015's Avatar
03.20.2012, 07:40 PM
Did you check each cell individually? Is there a single bad cell? If not, it may be a bad connection.
I've tried to revive lipo cells that had a low charge when I bought them - they worked OK for a bit, but didn't do well in the long term. Others may have had more success.
anunaki
03.20.2012, 08:31 PM
good info
03.20.2012, 09:34 PM
It has been possible to revive 'dead' lipos by charging them using nimh/nicad mode on your charger, just use a low charger current and hit it until the voltage rises above ~3.2v per cell ( of 6.4v total for a 2s pack ).
If there are zero volts though I would agree, check each cells individually, sounds more like a broken or cold joint inside the pack..
anunaki
Smile 03.20.2012, 11:35 PM
Damn mann you were right on the money one
of the balance soldering was broken I fixed it with a small peice of solder thanks and
thanks again
