SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
04.01.2006, 03:19 PM
Basically, reverse throttle means "enter." It moves you to the next parameter and you should hear a 2 or 3 beeps.
The number of times you apply forward throttle corrisponds to the mode number at the top of the chart and you should hear 1-2 beeps each time. Example: If you are in parameter "C," and you want the 0.26 second acceleration setting, you apply forward throttle twice, making sure the controller does its 1-2 beeps each time. Once you do that you press enter by applying reverse throttle until the controller does its 2-3 beeps (It lets you know that the setting is saved). Now you're in parameter "D," and you repeat the process until you are through with all of the parameters. If you do not wish to change a parameter, you may press enter to skip to the next one. However, you cannot skip parameter A. You must hit forward throttle once until it beeps, to get into car mode, and then you press enter until it beeps. Now you're in parameter B. I hope I explained it clearly enough. Let me know if I didn't.
Area 52 Ranch Raceway
T.R.C.R.
