jhautz
jhautz's Avatar
05.30.2012, 02:41 PM
It will fit and will allow for larger pinions, I'm not sure how large though.
Rc-Monster also makes a center spool that holds nitro revo spurs (mod1) that allow spurs down to 34 tooth, another way to "gear up". I'll add a link in a few minutes.
Yes. I have the RCM mount and the Revo spool with the 40T revo gear in my DM1e spec. Works great. Running the hobbywing 150a esc and 2000kv motor on 6s. Brutally fast and can run a full pack of full speed asphalt oval without anything overheating. I had it out with this new gearing setup last week and it was the fastest thing on the track. There were a couple guys running cars that were faster but they could only do a couple speed runs and then had to shut down to cool. I was able to run a full 6s 4000mah pack and it came off around 160. Hot but not overheated. Let it cool for 15 min and go run again.
The RCM mount is WORLDS better than the POS mount the car came with. Id recommend upgrading even if you aren't looking for additional gearing options.
to make it...
or break it...
Silent...But Deadly
