zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.14.2012, 11:35 PM
Well it looks like I am not the only one with the issue then. It never used to do this up until a few weeks ago, but I thought it was the older packs I had. But I have been trying to put a few light wake up cycles on some new 6s 2200mah 45c G3's. (which, btw, are tiny!)
Some of you are saying that the cells will go up and down; I have some old old A123 packs with balance taps that I tried and the cell imbalance will continue to increase... 0.03v gap....0.06v gap....0.10v gap, it's retarded. The only way I could get them within an acceptable balance was to use a resistor through the balance tap.
I bought a HP Sentry 2, so maybe i'll just use that for balancing the pack will charging, not that a G3 pack will need much balancing anyway.
