Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
mothman
06.19.2012, 10:19 PM
There is no room for fins - the diff cup is aluminum and the slipper-side endcap has vents to promote better cooling, though. Slip generates heat, but the components can withstand very high heat without detriment. As Harold said, unless it is affecting handling in a negative way, I wouldn't sweat it too much. :-)
Mike,
What type of aluminum did you use for the diff cup? and what type of coating they have? are they hard coated or just normal black anodized?
