2200kv Rotor Magnets Shattered....
Badkad
2200kv Rotor Magnets Shattered.... - 07.02.2012, 04:35 PM
I ran 6s in my buggy as normal... and then this happens!!!!!!! Completely ruined my bashing session and my day!!! Not like i was running ridiculous gearing either. I hope castle can sort me out as I can't use my Losi 8 2.0 anymore :(
07.02.2012, 09:29 PM
Gearing wouldn't make any odds, it the motor rpms that do something like that; first shattered Castle rotor I've seen from these motors...
Contact the support department:
http://www.castlecreations.com/support.html
Is the inside of the motor damaged, damaged windings of stator? If not, a rebuild kit should do the trick, otherwise whole new motor needed- if it's over 12 months old then it'll be a non-warranty repair fee...
Badkad
07.02.2012, 10:09 PM
Nope, luckily the windings and the insides look fine. Its just the rotor. 1st guy to have a shattered rotor....Am I unlucky or what :(
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.03.2012, 10:47 AM
Wow, thats a first.
fastbaja5b
fastbaja5b's Avatar
07.04.2012, 01:37 AM
Not the first, Traxxas VXL Motors do it all the time!
Say Less, Do More.
07.04.2012, 03:25 AM
Oh there have been plenty of shattered rotors on brushless motors.
This is the first Castle/Neu motor with it's superior kevlar wrapping that we have seen 'sploded.
Pdelcast
Pdelcast's Avatar
07.05.2012, 02:50 PM
We've seen a few come back with shattered rotors, but it's very rare.
If you can't get a good resolution from Tech Support (I imagine they will just send you a rebuild kit...) let me know here.
Patrick del Castillo
President, Principle Engineer
Brow
RC Drag racer
Brow's Avatar
07.06.2012, 02:19 AM
Now that's good service. I doubt the president of any other company will give such a response on a forum!! Customer service with a BIG Capital C & S.
I have a few Castle products and have not had any need to contact them for service but am impressed all the same.
Chainsaw10
07.16.2012, 08:28 AM
My 2200 motor seized up yesterday...the magnets are just starting to break(not as crazy as the op's). Im definitely not complaining as I have been abusing this motor for over two years now. My question is , will the rebuild kit work for me?
Here's some crappy pics. Hopefully you can see well enough to advise me if I can rebuild. Or just buy a new motor...thanks.
07.16.2012, 12:07 PM
Inside of the motor looks good to me- the magnets would tear it up something nasty and you'd definitely see the scaring if that was the case. Might just wanna use a clean rag or old toothbrush to clean the inside of the motor while it's open, then a new rotor kit should do the trick nicely...
Chainsaw10
07.18.2012, 03:59 PM
Thanks! Got the rebuild kit and installed it.....good as new. That was simple.
07.18.2012, 04:28 PM
Can I use my wife's toothbrush, and not tell her? Should I use colgate whitening paste? I have heard that 10 out of 5 dentists recommend not using a toothbrush as a replacement for a rectal suppository applicator. Is that true? Neil, I know you are basically one step below the all-mighty (you are about level with the pope) so you should be albe to answer these questions.
07.19.2012, 11:45 AM
Sure, use wifeys brush but be careful not to get any grease on it. Don't use any paste or lube on the brush ( just insert it into the hole dry ). I can think of worse things to use as a suppository applicator ( hamster & toilet tube delivery system? ). I'm one step ahead of the pope though, I don't try to cover up scandals concerning children and catholic priests...
