07.18.2012, 01:18 AM
Anything cheaper than the pyle I linked to would be super cheap and shady. Pyle is inexpensive but quality.
A similar bazooka tube (high end) would be $300+
Do you have the owners manual for the cd player? If it has built in crossovers you can use those to completely eliminate any bass from going to your front speakers. (recommended)
You can find a manual online if you don't have one.
If you don't have crossovers I recommend setting the bass to zero, and do whatever you want with the highs.
If you do have crossovers, you don't need to turn the bass level down, because the deck is already blocking the bass for you, but you'll have to set that setting.
What's the decks model number? I'll take a look and be able to give you better advice.
