First of all apologies again for having the same question in 2 separate threads... my fault and it wasn't a good idea.
Anyway,
Thanks suicideneil, from what you posted I think I'm understanding the issue a bit more, I surmise if the rx is powered from the same source powering the servos, things should workout.
Brainstormed the information gathered here (I'm no electrical Engineer); got some time and did some bench test trials; first diagram:
Have the external BEC get the same power source as the ESC.
RX is powered by the internal Bec of the ESC
Servos are powered by the Exernal BEC
Tested on bench and it worked.
The second trial, what i understood is that the if the RX is powered from the same source powering the servos, things should workout. Well also tried it on bench and it also worked;
Got a separate third 3S battery as source for the external BEC.
Disconnected the red wire between ESC and RX.
Powered the RX from the external BEC out.
Servos obviously get power from the external BEC out.
the only drawback is if i have the external BEC set to 7.2v it would fry the RX i think.
The following diagram should clarify this:
Yet to try, but i think should work;
Same scenario as in the second diagram;
Add a another external BEC 7.2v to power the steering servo.
The 6v external BEC would power the throttle servo and the RX.
Both external BEC's get same power source, the third battery.
AND AGAIN THANKS TO ALL FOR THEIR INPUT; IT WORKS
