Kcaz25
Kcaz25's Avatar
11.01.2012, 07:17 PM
I think I just nailed it!! I was so anxious to do it right! I ended up cleaning everything off the shaft! Including the copper strip. I mounted it back though of course and with that same green lock! I had to clean out that slot that the copper strip inserted into first. I did this with the point of a razor blade I then laid the razor blade flat to scrape out the old green glue in the two big slots. I covered those locations in green lock already have my pinion stop ready I grabbed the rotor and very quickly slid into until it stopped necessarily at my pinion stop. I had to make sure the strip went into the grove on the inside of the rotor aswell! done! I will test it tomorrow!
the finished picture would be boring. You've seen a healthy rotor
