Need some help: Fully custom build was fine, now having throttle range issues
11.27.2012, 11:31 PM
Solder connection, either on battery to esc, or esc to motor. Do you run 2x3s? Have you ever swapped out your series connector to rule it out?
Something is getting hot quickly and failing... feel connections separately for heat when this happens...
Find all posts by _paralyzed_
2
11.27.2012, 11:35 PM
Deans plugs? I suspect a solder joint, or possibly a bad plug on the series connector...
Hybrid Mode
Switch to Threaded Mode
