Thread Tools Rating: Thread Rating: 32 votes, 4.94 average. Display Modes
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.16.2013, 10:05 PM
If you have a multimeter that has a frequency display, you could use that to get an idea of the frequency; sometimes frequency measurement is a mode of AC voltage measurement. This won't tell you the duty cycle though, for that it will just take some experimentation. It would be much faster to borrow a oscope if at all possible.
I'd start by trying to nail down the frequency by starting with fan rpm - 66Hz for a 4000rpm fan. 4000 rpm (rev/min) is 66.67 rev/sec (Hz=rpm/60), and then double it if that doesn't work, and so on. Once you get the frequency, start with a low duty cycle (very narrow pulse) and work your way up to 50% duty cycle.
The 555 timer will allow adjustments in both frequency and DC% (duty cycle). However, there are a few things to consider. IIRC, a 555 timer will have limits on DC%, if it won't get as narrow (or wide) as you need, you may need to use a transistor configured as an emitter-follower which will basically "invert" the output. Also, adjusting the resistances tends to adjust both freq and DC% at the same time, so sometimes it is easier to use two 555's in series, the first one as the astable oscillator to generate the right frequency, the second as a monostable oscillator to adjust the DC%. More complex but much easier to control freq and DC% independently. The 556 timer is just two 555 timers in one IC case, so that might be a better way.
I know you want to replace both fans, but how loud is just one fan by itself? Because like I said, you could tap into the tach signal of one fan and feed it to the other input and then use whatever fan you want as the second one if you need it.
If you still want to go with building your own oscillator, here are a couple datasheets for the 555 and 556 timers. Each has an applications section at the end with circuit examples: 555 Timer, 556 Timer.
I will have to look at that, possibly also using a thermister to control fan speeds. Read up a bit on that last night. Never really got into building circuit boards, but I can follow a diagram and do the math. So I'll eventually do that. Kinda tapped out for money currently.
In the mean time? I present a PSU.....in a box. This box was meant for the safe transport of LTO3 tapes in a very sensitive fashion. Which means the plastic is quite thick, and the open cell foam padding makes an adequate sound insulator.
I drilled a few holes in one side for the cables. Though I will visit radio shack tomorrow an pickup some insulated terminals for banana plugs and mount those to the box so I don't have to feed the charger leads through the air hole I made. I used a 92mmn 44cfm 41db PC fan for exhaust. I may add another 92mm fan to the front of the case of the same type if this proves insufficient. Using the left over padding I created and air dam to force air through the PSU.
So far its been running for about 1hr now and the air coming out of the fan vent is luke warm.
Before the box the PSU was about 74db, with the PSU in the box and lid closed its averaging 48db. Not a bad change for free.
psubox by thirdgen89gta, on Flickr
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
