WheelMan
Do Epic Sh!t
WheelMan's Avatar
06.04.2013, 02:34 PM
I was wondering if someone would point that out. Do you think it will effect the performance of the suspension? It really shouldn't make a difference should it?
Reason the shocks are on the inside is because I wasn't paying attention when I mounted the shock towers. Because of the design of UE's towers, with the little body post retainers, the body posts are off center on the towers. And I went and drilled my body to fit to the towers the way they are mounted right now, with the body posts offset to the outside. Also, unfortunately, the piggybacks I just installed on my shocks interfere with the screws holding the body post retainers onto the towers if I install the shocks on the same side as the retainers (the outside). In other words, I can't mount the shocks on the same side of the towers as the body post reatainers, because the shocks will interfere with them. So, I had to move the shocks to the opposite side of the body post reatainers on the towers, giving enough room for the piggybacks to mount up. Not sure if that makes sense? Hopefully you followed what I was saying there? lol
If I hadn't drilled the body out, I could have just flipped the towers around, and put the body posts towards the inside, and mounted the shocks on the outside (how I'd much rather have it), exactly opposite of how it is now. But I don't want to have two sets of holes in my shell...so this is how its set up now.
-Travis
Adults are just kids, with money.
Common sense, is not so common.
