Lizard
Lizard's Avatar
08.26.2013, 08:46 AM
When you have split the pack in a seperate 3s and 4s pack you just charge each pack in the normal way.
When you have soldered the two packs in series, you need a charger that is capable of charging 7s.
For wiring look here:
http://scriptasylum.com/rc_speed/lipo.html
Scroll down to the last dropdown box and select "Hi Amp 3s +2s generic connector". This will show you how
to wire for 3s and 2s in series, for your case you just need to add one wire more on each side.
08.26.2013, 12:08 PM
You need to charge them separately as a 3s and a 4s pack. You cannot charge them together in parallel because of the different voltages.
Your only way to charge as one pack is to get a 7s capable charger and charge in series.
Charge them separately.
