Change Motor Timing to Lowest (0)
Bernie Wolfard
Clinically Inane
Bernie Wolfard's Avatar
Change Motor Timing to Lowest (0) - 04.03.2014, 11:48 AM
You must use the Lowest possible timing with any D wind motor (you can confirm on Neu Motors website).
Cogging only occurs on start-up. What you have is glitching probably caused by the radio system. This occurs with high torque/high speed digital servos running off the onboard BEC in an ESC. If this is the problem a separate more powerful BEC will resolve it.
Bernie
