Pdelcast
Pdelcast's Avatar
12.18.2014, 02:32 PM
Originally Posted by Dr_T View Post
Hi Patrick,
I'm thinking of getting an XL2 ESC, or its successor. Could you please explain how the Torque control and Current limit functions for the XL2 are related? Given your explanation above, they both do the same thing, no?
Thanks!
They are not related. Current limit is a maximum allowed average current (to protect the controller) and interrupts PWM. Torque limit varies PWM to limit maximum torque from the motor. Torque limit does not use the same hardware as current limit.
Thanks!
Patrick del Castillo
President, Principle Engineer
Dr_T
Dr_T's Avatar
12.18.2014, 05:59 PM
Thanks!
Thanks for your quick reply Patrick!
So, for limiting the magnitude of Current spikes, I should use the Torque limiter then, right? And what does "interrupting" PWM mean, setting throttle / motor input Voltage to zero?
Pdelcast
Pdelcast's Avatar
12.18.2014, 06:23 PM
Torque limit would be good for limiting current spikes during hard acceleration. The current limiter has just a couple settings, can't really be used as a general purpose current limit - -it's not designed that way. The PWM is shut down for several commutation cycles when it trips.
Thanx!
