GriffinRU
04.09.2006, 10:08 AM
Well it is going to a emaxx trans. The motors share the same spur. I plan on running them off a esc with double wires so when hooked together will try to phase them together. I just need another motor now.
Attach both motors to e-maxx tranny without pinions, solder wires from ESC to motor wires. Do not apply power to anything, just rotate by hand one motors shaft and second one will get into exact matching position. Get your ruler, hold it against shafts and draw the line on shafts. Now you set and good to go, do not forget to mark up and down sides on shaft. Check for spin directions as well...
Artur
